Calculating Forces Acting on 4 Spur Gears in a Machine
To calculate the forces acting on four spur gears in a machine driven by an 80kW motor, it's essential to consider the diameters of the gears and their pressure angle of 20 degrees. The input motor operates at 1850 rev/min, and the gear sizes are 100, 300, 133.34, and 266.66 mm. Users suggest utilizing online calculators and resources, such as the Spur Gear Calculator and various engineering websites, to derive the necessary equations and force calculations. Some users have encountered difficulties with software usability and downloading resources. Accurate calculations depend on knowing the geometric factors and applying the correct formulas for spur gears.
Mohhid786
Hi,
i would like some help on how to calculate the forces acting on each gear if the machine had 4
for example gear 1 has a diameter of 100, gear 2 has 300, gear 3 has 133.34 and gear 4 has 266.66
the machine is driven by an 80kW motor through a 2 stage gearbox having four spur gears. The input motor runs at 1850 rev/min and all gears have a pressure angle of 20 degrees
if anyone can give me a helping hand with this it would be of most help thank you
This link might do what you need: Spur Gear Calculator v1.07 http://www.dakeng.com/spurgear.html
It doesn't seem to accept pressure angles directly, but you should be able to derive what you need from the equations here: http://shopswarf.orconhosting.net.nz/spur.html
thanks for the link however its not letting me download it
The full version installed OK for me. On trying it out, it's not as useful as I hoped, though, but perhaps I'm not using it right. Its help file is in an old format and I didn't bother to try to install the old helpfile reader. Googling "spur gear calcultor" gives some other results, but I'm not sure what you need.
http://www.roymech.co.uk/Useful_Tables/Drive/Gears.html#Forces has some force formulas that should help once the other geometric factors are known.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
