Determine is endomorphism, kernel, epimorphism, monomorphism
  • Thread starter Thread starter Shackleford
    Kernel
Shackleford
I'm reasonably certain I did 1b correctly. I'm not sure about 1h. In both cases, since phi is the transformation from the multiplicative group G to the multiplicative group G, the identity is 1.
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110729_200311.jpg?t=1311988303
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110729_200408.jpg?t=1311988318
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110729_200704.jpg?t=1311988336
Seems to be entirely correct! :smile:
One small detail, though. You checked that 1b was a monomorphism directly with the definition. This is unnecessary work as you also calculated the kernel. Knowing that the kernel is {1} is good enough for showing it's a mono.
Yup, looks good.
Thanks for checking my work.
How does the kernel = {1} show one-to-one?
SammyS said:
Yup, looks good.
Thanks.
According to the definition, a homomorphism is an endomorphism if the mapping is to itself, i.e. G = G'. So, in this problem, since G = G (R - {0}), you just have to show it's a homomorphism or not.
You could try showing this! It only requires the definition of a group homomorphism. And it's actually both a necessary and sufficient condition (it'll be an "if and only if" proof).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
