Speed Of A Bullet Before It Strikes A Block Of Wood
The discussion revolves around calculating the velocity of a bullet before it strikes a block of wood, given specific parameters like mass, distance, and friction. Two methods were attempted to solve the problem, both leading to the same result of approximately 166.32 m/s for the bullet's velocity. The first method uses energy conservation principles, while the second applies kinematic equations. A suggestion was made to simplify calculations by using g = 10 m/s² for easier computation in introductory physics contexts. The calculations and methods used appear to be correct and on the right track.
amber87
A 10g bullet strikes and becomes embedded in a 0.200kg block of wood placed on a horizontal surface just in front of the gun. If the coefficient of sliding friction between the block and the surface is 0.4 and the impact drives the block a distance of 8m before it comes to rest, what is the velocity of the bullet before it strikes the block of wood?
E(kinetic)=E(frictional)
1/2(m1+m2)v2^2=μ(m1+m2)gs
or
ma=μmg
a=μg
v^2=u^2+2as
v1(m1)=v2(m1+m2)
I've tried 2 different ways to do it which are:
1.)
m1=0.010kg
m2=0.200kg
s=8m
μ=0.4
1. E(kinetic)=E(frictional)
1/2(m1+m2)v^2=μ(m1+m2)gs
1/2(0.210)v^2=0.4(0.210)(9.8)(8)
v2=7.92m/s
m1v1=(m1+m2)v2
0.010v1=0.210*7.92
v1=166.32m/s
2.)
ma=μmg
a=μg
a=0.4*9.8
a=3.92
v^2=0
a=-3.92
s=8m
u^2=?
v^2=u^2+2as
0=u^2+2(-3.92)(8)
u^2=7.92
m1v1=(m1+m2)v2
0.010v1=0.210*7.92
v1=166.32m/s
I'd love to know if I'm on the right track here. Thanks a million in advance.
or
ma=μmg
a=μg
v^2=u^2+2as
v1(m1)=v2(m1+m2)
1.)
m1=0.010kg
m2=0.200kg
s=8m
μ=0.4
v2=7.92m/s
m1v1=(m1+m2)v2
0.010v1=0.210*7.92
v1=166.32m/s
2.)
ma=μmg
a=μg
a=0.4*9.8
a=3.92
v^2=0
a=-3.92
s=8m
u^2=?
v^2=u^2+2as
0=u^2+2(-3.92)(8)
u^2=7.92
m1v1=(m1+m2)v2
0.010v1=0.210*7.92
v1=166.32m/s
I would have used your method 1. and agree with your calculations.
There is a chance, that if this was an introductory physics question, that you were only required to use g = 10. This makes calculations much simpler and able to be done without a calculator. In that case that first velocity is 8, and the initial velocity this 168 m/s,
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
