Calculating maximum amount of water vapor per unit volume
guitarstorm
Compute the maximum amount of water vapor per unit volume that air can hold at the surface, where Ts = 288 K, and at a height of 10 km where T = 220 K. Express your answers in kg m-3.
e_{s}=Ae^{\beta T}
e=\rho _{v}R_{v}T
Since saturation occurs when e=e_{s}, I figured I would set the two equations equal to each other. However, solving for \rho _{v} doesn't work... The units don't work out, and I get a really large number... I feel like I have to somehow relate this to the total pressure of the air, but I'm unsure how to go about this.
I was incorrect in my previous post saying that the units didn't work out... Solving for {\rho _{v}} when e=e_{s} does produce an answer in \frac{kg}{m^{3}}... However I'm getting 1,103,248.397 \frac{kg}{m^{3}}, for the first case where T=288 K, which is way off from what I should be getting (0.0126 \frac{kg}{m^{3}}).
I believe I then have to use the ideal gas equation, pV=nRT, plugging in p for e... But this is where the confusion comes in. Hopefully someone can help me with this tonight, since this HW is due tomorrow morning...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
