Should I Use Absolute Values in JFET Calculation?
  • Thread starter Thread starter Monsu
    Calculations
In JFET calculations, the equation Id = Idss(1 - (Ugs/Up))^2 is used to determine the drain current. The question arises whether to use absolute values for Ugs and Up. It is clarified that while absolute values are necessary for p-channel JFETs, they may not be required for n-channel JFETs. The discussion emphasizes the importance of understanding the context of the voltages involved. Proper application of these values is crucial for accurate calculations in JFET analysis.
Monsu
HI,
When doing some calculations for a JFET (n-channel), I guess u all know this equation:
Id = Idss( 1 - (Ugs/Up))^2
my question is, am i supposed to take the absolute values (modulus) of Ugs and Up?
Id = drain current
Idss = saturated drain-source current
Ugs = gate-source voltage
Up = pinch off voltage.
pls, kinda an urgency!
thanks! :smile:
u cam take the modulas in case of p-jfet
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
21K
18K
