Move a Tricycle: Calculate X_current Position
  • Thread starter Thread starter transilvanian
To calculate the new position of a tricycle, define the initial position as X_initial = (x, y, theta) and incorporate the angle of the front wheel (phi), speed, and duration. The distance between the back wheels and the front wheel is Z cm, which is crucial for the calculations. A function can be created in MATLAB or any programming language to model the motion, using a time vector to represent the duration of movement. The new position X_current can be expressed as a combination of the initial position and the parametric equations for x(t), y(t), and theta(t). This approach allows for flexible path modeling, such as circular trajectories.
transilvanian
Hi,
I have a fairly simple question, but I am a newbie. I have to move a tricycle from one position to another. The position of the middle of the two back wheels is described as X_initial = (x, y, theta). The function (in matlab, but I guess it could be in any language) should take in parameter the initial position, the angle of the front wheel (phi), the speed of the front wheel (meter/second) and the duration (in second) and then return the new position X_current (x,y, theta).
The distance between the two back wheels is Z cm and the distance between X and the front wheel is also Z cm.
How can I calculate such a problem?
Thanks
are you trying to write a function modelling the motion of your tricycle?
make a vector t, t=t0:tmax (t = [0 1 2 3 4 ... tmax]
Pos = < X0 + X(t), Y0 +Y(t), theta0 + theta(t) >
choose x(t), y(t), and theta(t) to parametrize any curve you want the tricycle to take, like a circle. hope this helps
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
