How Many Homomorphisms Can Be Calculated Between Different Fields?
  • Thread starter Thread starter wattsup03
    Homomorphisms
wattsup03
Hi,
I am trying to calculate the number of homomorphisms from one field to another:
a) F2 ---> F3
b) Q[X]/(X7 - 3) ---> Q[X]/(X8 + 4X5 - 6X + 2)
c) F7 [X] / (X2 + X - 1) ---> F7[X] / (X2 + 1)
d) Q( 21/4 ) ---> C
Attempt at a solution
a) I'm pretty sure there are no homomorphisms between F2 and F3 because if there was a homomorphism f, then f(1+1) = f(0) which does not equal f(1) +f(1) = 2
b) I think I need to see how many roots there are of X7 - 3 in Q[X]/(X8 + 4X5 - 6X + 2) since there is a bijection between that and the number of homomorphisms?
c) Similarly here
d) For this one I think the answer is four (I'm really not sure) because there is a bijection between K-Homomorphisms and the roots of the minimal polynomial of 21/4 in C, which would be 4. And over fields K-homomorphisms are ring homomorphisms?
In all honesty I am pretty stuck, and if anyone could give me any advice that would be fantastic.
Thanks in advance.
a) I agree
b) I am thinking that a homomorphism f will be uniquely defined by f(x)
Prove it.
But 0 = f(0) = f(x^7 - 3) = f(x)^7 - f(3) = f(x)^7 - 3
and how many solutions does this have?
But I suppose we have to bear in mind that this zero is k(x^8 + 4x^5 - 6x + 2) for any k
c) similar
d) Using this same method would seem to imply the identity is the only homomorphism, but there are 4 K-Homomorphisms as you said, so we are in trouble here
This is still a work in progress for me but I hope it helps
Thanks meandonlyme ,
for b) could I put x7 - 3 into Q[X]/(X8 + 4X5 - 6X + 2)
(which is x7 - 3 still) and then calculate the number of roots in there: 1 since it is over Q.
So there is one root and hence one homomorphism.
Similarly for c) and d)
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
