Thrust to Power Ratios for Modern Propulsion Systems
Thrust to power ratios for modern propulsion systems vary significantly based on vehicle type and speed. A reference cited indicates a thrust to power ratio of 0.016 N/W for a DC-9 jet engine, but the accuracy of this figure is questioned. The discussion highlights that these ratios can be more meaningful when considering efficiency curves rather than fixed numbers. Participants express uncertainty about where to find comprehensive data on thrust to power ratios across different propulsion systems. Overall, the conversation emphasizes the complexity and variability of these ratios in practical applications.
syberraith
Does anybody know some ballpark figures for thrust to power, Newtons per watt, ratios for modern propulsion systems, mechanical drive train ie cars trucks, propeller driven craft, boats planes, and rockets.
I've found one reference that states the F/P ratio for a DC-9 jet engine is 0.016 N / W. Is that accrurate?
Thanks,
Fred
I'm not sure such a ratio has any meaning, since for most vehicles it varies with speed.
Yes, I've read that efficiency numbers for propeller driven air craft very with the vehicles air speed.
Curves would do just as well.
I just am clueless as to where to start looking for that information.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
