Using an L.E.D. as a diode to control current flow?
Using LEDs as diodes in a crystal radio is not advisable due to their high forward voltage drop and low tolerance for reverse voltage, which can lead to signal interference. For optimal performance, small signal Schottky diodes like the BAT85 or point contact Germanium diodes are recommended, although the latter may be hard to find. Standard silicon diodes are also unsuitable for this application. A crystal radio relies solely on energy from the antenna, making the choice of diode critical for effective operation. Therefore, sourcing appropriate diodes is essential for successful crystal radio construction.
rollcast
I'm trying to make a small crystal radio and have managed to wire up the antenna and the head phone jack but I haven't got any diodes suitable for the voltages I'm using. I have some LEDs but will these dissipate too much current or cause any harmonics or interference with the signal?
It might work, but LEDs tend to tolerate only low reverse voltages (say, a few volts rather than the 700 volts of a 1N4007 power diode or even the 100 volts of a 1N4148 signal diode). In forward mode, they also usually have a much higher voltage drop (1.5 to 4 V) as compared to the ballpark for most diodes (0.3 to 0.7 V)
For a crystal radio, you will need diodes that turn on easily with a very low voltage.
Suitable diodes are small signal Schottky diodes, like the BAT85, or point contact Germanium diodes.
These Germanium diodes are fairly scarce now, but you may find them on Ebay or somewhere.
Like these:
http://www.ebay.com.au/itm/LOT-10-1N34A-Germanium-Diode-AM-FM-Radio-TV-/220585057201?pt=LH_DefaultDomain_0&hash=item335be4dbb1
LEDs are not suitable, nor are any kind of Silicon diode.
What does this mean? A crystal radio (aka crystal set) does not normally use any input power apart from what comes from the antenna.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
