Complex roots of a cubic equation
engineer1406
Hi all,
I was wondering if there is a procedure you can follow to calculate the complex roots of a cubic equation.
For example the equation
x3 - 1 = 0
has roots of x = 1
x = -0.5 + √3/2 i
x = -0.5 - √3/2 i
Admittedly, I got those solutions off wolfram alpha, but I am wondering how to work it out without wolfram!
Thanks!
In this case, it's not so hard. If you have a complex number z, then you first need to write it in the form
z=R(\cos(\theta)+i\sin(\theta))
It is now a theorem (prove this!), that the n-th roots are exactly
\sqrt[n]{R}(\cos(\frac{\theta+2k\pi}{n})+ i\sin(\frac{\theta+2k\pi}{n}))^n
for 0\leq k<n. This is due to De Moivre's identity.
So, can you use this information to calculate the third roots of 1?
Haha, great. The formula works!
Thanks very much micromass!
Here's another way to do it (not as "sophisticated"): x^3- 1= 0 has the obvious solution x= 1 so x- 1 is a factor. Dividing x^3- 1 by x- 1, we find that x^3- 1= (x- 1)(x^2+ x+ 1). If x is not 0 then x^2+ x+ 1= 0. That's a quadratic equation so use the quadratic formula to solve it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
