What is the velocity and direction of the wreckage after the collision?
  • Thread starter Thread starter Jameson
    Momentum
The discussion focuses on calculating the velocity and direction of wreckage after a collision between a car and a truck. The car, weighing 2082 kg, was traveling east at 14.3 m/s, while the truck, weighing 4070 kg, was moving north at 10.8 m/s. After the collision, the combined mass of the wreckage is 6152 kg, resulting in a velocity of 8.63 m/s. The angle of the wreckage's direction is calculated to be 55.9 degrees from the east. The conversation emphasizes the need for resolving the momentum equations in two dimensions to find the correct angles.
Jameson
Insights Author
MHB
A 2082 kg Oldsmobile traveling east on Saginaw Street at 14.3 m/s is unable to stop on the ice covered intersection for a red light at Abbott Road. The car collides with a 4070 kg truck hauling animal feed north on Abbott at 10.8 m/s. The two vehicles remain locked together after the impact. Calculate the velocity of the wreckage immediately after the impact. Give the speed for your first answer and the compass heading for your second answer. (remember, the CAPA abbreviation for degrees is deg)
So, you can add the momentums like vectors to get the resultant.
Pr = sqrt {((2082)(14.3))^2 + ((4070)(10.8))^2}
Pr = 53089.9 N*s
P = P'
So, 53089.9 = (combined mass)v'
v' = (53089.9)/(6152)
v = 8.63 m/s
and the angle.
theta = tan(inverse) of (43956)/(29772.6)
= 55.9 deg
HELP ME
Resolve the problem into two different equations since it's in 2D
x direction:
m1 * v1 * cos(theta) + m2 * v2 * cos(theta') = (m1+m2) * v3 * cos(theta'')
y direction:
m1 * v1 * sin(theta) + m2 * v2 * sin(theta') = (m1+m2) * v3 * sin(theta'')
i don't know what angles to use. can you please be more specific. i need help!
Someone, come on. I know basic physics. Give me a freakin bone.
On the LHS of the equation Nothing gave the angles are given in the problem (east and north). You'll have to solve for the angle (its the same for the x and y direction equations) on the other side.
