How Do You Calculate Angular Acceleration and Time for a Turntable Platter?
To calculate the angular acceleration of the pottery wheel, it is essential to recognize that both the small rubber wheel and the larger platter have the same angular acceleration due to the no-slip condition. The angular acceleration can be determined by the change in angular velocities over time. For the second part, since the acceleration is constant, the relationship ω = a*t can be used to find the time it takes for the platter to reach 33 1/3 rpm. Dimensional analysis may be necessary to convert units appropriately. Overall, understanding the relationship between the two wheels is key to solving the problem effectively.
oranrene
4. (9) On an old style record turntable a small rubber wheel is used to drive the larger platter. They are mounted so that their circular edges touch and do not slip while in motion. The small wheel has a radius of 2.0 cm and accelerates at the rate of 3.5 rad/s2 while it is in contact with the pottery wheel of radius 28.0 cm.
Find: a) the angular acceleration of the pottery wheel
b) the time it takes the turntable platter to reach 33 1/3 rpm
v=rω
f=ω/2∏
t=1/f
I honestly have no clue where to even begin. I have no clue how to set this up.
The roll without slipping is all you really needed. It means the larger wheel spins as fast as the smaller wheel (as if they didn't, one would be slipping past the other).
This means their ANGULAR accelerations are both the same. The angular acceleration is just the change in their angular velocities (per unit time of course). That should answer the first part for you.
The second part is simple, since the acceleration is constant, the angular velocity will just be a a linear function of time.
ω=a*t (where a is the angular acceleration). All you have to do now is change the units (through dimensional analysis or whatever you like to call it).
Thankyou very much. I actually found an example in my book very similar to this one (My teacher is very bad at changing questions -_-) and was able to figure it out. Your explanation was very helpful though thankyou.
