Determine the direction of induced current in a wire
A wire carrying current experiences a force in a magnetic field, relevant for devices like electric motors. When the current is turned off and the coil is rotated, the induced emf varies with the angle, peaking at 90 degrees. The direction of the induced current can be determined using Fleming's right-hand rule, which relates the direction of force, velocity, and magnetic field. The discussion highlights the importance of understanding how the angle affects the magnitude of the induced emf. Overall, the interaction between the coil's motion and the magnetic field is crucial for determining current direction.
phosgene
A wire carrying a current experiences a force when it is placed in a magnetic field. This phenomenon forms the basis of many devices including the electric motor and the gavlvanometer.
The diagram shows a uniform magnetic field B with magnitude 25mT directed towards the right. in the plane of the page. Initially, the coil ABCD is in the plane of the page. Each arm of the coil has length 1 = 50mm.
c) The current is turned off and the coil is rotated through 360 degrees about the axis shown. Sketch a graph showing the current flowing in the coil because of the induced emf as a function of the angular position of the coil. Explain how you determine the magnitude and direction of the current at each stage of the motion of the coil.
EMF = 2NBlvsinx, where N = number of loops of wire, B = strength of magnetic field, l = length of wire, v = velocity of wire and x = angle subtending the magnetic field lines and coil of wire.
If the velocity is constant, then the magnitude of the EMF is is determined by the angle x, and will be at a maximum when x = 90 degrees and at a minimum when x = -90 degrees.
I don't know how I can determine the direction of the current at each stage of the motion of the coil, however. The equation for EMF will tell me when it flows from positive to negative, but how can I tell which direction positive and negative are in?
It is a force on the electrons in the wire that causes the current to flow.
If you know your hand rule for that force F = q*v*B, you can use it to find the direction of electron flow.
I think I got it now, I used Fleming's right hand rule. Thanks :)
Most welcome. Interesting, I didn't know it was attributed to Fleming.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
