Motion Attachment: A Scientific Inquiry
  • Thread starter Thread starter maru1721
    Motion
maru1721 said:
Hello maru1721. Welcome to PF !
Is there a question here?
You need to show some work / effort, before you can be helped here.
Here is what i had done but still did get them correctly. Anyone who can help please.
