Does Electron spin generate electricity?
Electron spin generates a magnetic field but does not directly produce electricity. Electricity is not a singular concept; it encompasses current, voltage, and other properties. In electrical circuits, moving charges, specifically electrons, are responsible for generating current and voltage. An individual electron does not create voltage or current by itself, as current is defined by the movement of electrons. Therefore, while electron spin contributes to magnetic fields, it does not generate electricity independently.
romsofia
I know that with the electron spin generates a magnetic field, but does it generate an electricity?
Thanks for any input!
A short answer is no, it does not. Electricity isn't a well defined thing. Current, voltage, and other properties are however. In any electrical circuit you will have moving charges, electrons in the case of normal circuits, which enable us to use their electric and magnetic fields to perform work. On it's own an electron doesn't generate voltage or current, especially since moving electrons ARE current.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
