Solar panels - Direct charging and battery life
Directly connecting a solar panel rated at 6 volts to a 6-volt device can negatively impact the device's battery life due to potential overcharging or reverse current issues. Without an electronic controller, the solar panel may draw current from the battery at night, leading to battery drain. Using a diode or a controller is recommended to prevent this reverse current and ensure safe charging. Small solar panels typically won't damage larger batteries, but caution is advised with direct connections. Proper regulation is essential for maintaining battery health and longevity.
ramonegumpert
Dear Experts
There are solar charging devices in the market for electronic devices.
These contain some electronics which I suppose is to regulate the power or as controller.
Lets say I have a 6 volts device and I have a solar panel rated at 6v.
If without any electronic controller, I just hook up the panel to the device, will this sort of what i call 'direct' charging affect the device's battery life? If so, in what way ?
Thank you for reading my post.
I wish you a nice weekend.
regards
Ramone
It depends on the current that is produced, as you might expect. A small solar panel is unlikely to damage a car battery, for example.
However, directly connecting a solar panel to a battery is not a good idea because the solar panel can draw current from the battery during the night.
A diode or some other method of stopping this reverse current is usually added. Your controller would already include this.
Thanks so much Vk6kro!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
