Running a vehicle by burning aluminium?
Aluminium is noted for its high energy density and potential as a fuel source, particularly when smelted using green electricity. The discussion explores the idea of generating energy by burning aluminium wires through electric arcs, which could produce light and heat that might be converted into electricity for vehicle propulsion. However, practical challenges exist, such as the formation of aluminium hydroxide and the efficiency of recycling aluminium oxide compared to using raw ore. Additionally, conventional heat engines may be more effective than attempting to harness energy from the combustion of aluminium. Overall, while the concept holds promise, significant hurdles must be addressed for practical implementation.
johne1618
Apparently aluminium has the highest energy density per unit volume of any material.
It can be smelted from ore or recycled oxide using green electricity.
People have made batteries using aluminium but they have problems like getting gunked up with Aluminium hydroxide etc.
How about burning two aluminium wires by striking up an electric arc between them?
If the temperature is high enough I guess the aluminium oxide will come off as a vapour rather than coating the wires and stopping the combustion.
The light and heat could be turned into electricity using photovoltaic cells and thermocouples and could be used to run an electric motor to drive a vehicle.
The oxide ash could be captured and recycled.
Nothing wrong with this in principle but, in practice, there would be many difficulties. Re-cycling Aluminium Oxide may not be as good value as using the vast quantities of readily available Aluminium Ores (however offensive that may seem) because you would have to harvest small quantities of waste from all the engines and get it to the sources of green electricity. To be worth while, I think the reduction process needs to be done on a big scale.
Also, using the energy from the 'flame' might be better achieved with a conventional Heat Engine. Perhaps an Aluminium Powder fuel could be used to fuel a boiler?
Iron thermite is VERY hot: Fe2O3 + 2 Al → 2 Fe + Al2O3
Poor man's welding kit. Watched some rails being welded together once. Very impressive. But high thermodynamic efficiency - if only you could make a suitable engine / cycle.
Also Aluminum thermite ...makes a wonderful explosion when coupled to ice...as shown by Mythbusters here (wait 'til end of clip):
Care to speculate why.?
Creator
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
