Centrifugal Force and the Path of a Moving Particle in a Rotating Tube
A particle projected towards the axis of a rotating tube experiences an inertial force due to centrifugal force, described by the equation m\ddot r = mrω². The discussion focuses on deriving the particle's path using Newton's second law, leading to the differential equation \ddot r = ω²r. By multiplying this equation by the radial velocity \dot r and integrating, the relationship \frac{1}{2}(\dot r)² = \frac{1}{2}ω²r² + c is established. The integration process is clarified as a formal procedure involving the manipulation of differential equations. Understanding this method is emphasized as it is frequently applicable in similar problems.
azizlwl
"Centrifugal force"
A smooth horizontal tube of length l rotates about a vertical axis. A particle placed at the extreme end of the tube is projected towards O(axis) with a velocity while at the same time the tube rotates about the axis with constant angular speed ω. Determine the path.
Solution
The only force on the particle is the inertial force("Centrifugal force") mrω2
Newton's second law becomes
m\ddot r=0+mrw^2 \ or \ \ddot r=ω^2r
This part I don't understand
Multiplying\ by\ \dot r dt=dr \ \ and\ integrating
\frac {1}{2}\int d(\dot r)^2=w^2 \int rdr
\frac {1}{2}(\dot r)^2=\frac {1}{2}w^2 r^2 + c
Blurr at differential equation.
The (radial) velocity is the time derivative of r: \dot r= dr/dt
You can multiply the equation \ddot r= \omega^2 r by \dot r and you get \ddot r \dot r = \omega^2 r \dot r. The left hand side is the time derivative of (\dot r)^2 /2, the right hand side is the time derivative of \omega^2 r ^2 /2. So integrating both sides of the equation leads to \frac {1}{2}(\dot r)^2=\frac {1}{2}w^2 r^2 + c .
The formal procedure is that the equation \ddot r \dot r = \omega^2 r \dot r is written as \dot r d\dot r/dt = \omega^2 r dr/dt and multiplied by dt and then putting integral signs in front of both sides:
\int{\ddot r d \dot r}= \int{\omega^2 r dr}
ehild
ehild
The formal method you mentioned is easier for me to understand.
Thank you
OK. Remember that procedure, it is applied quite often.
ehild
