Working out voltage drop and current flowing through a circuit
The discussion focuses on calculating the current and voltage drop in a series LED circuit powered by a 12V battery. The circuit consists of 28 parallel strings, each containing 3 white LEDs (3.4V each) and a resistor. The total voltage across the LEDs is 10.2V, leaving a voltage drop of 1.8V across the resistor. To achieve a current of 10mA, a resistor value of approximately 180 ohms is suggested, with a 100-ohm resistor being a practical alternative. The total current for the circuit would be 280mA at 10mA per string or 560mA at 20mA per string.
SummersLCFC
I have just wired up a LED circuit in series of 3 with a resistor of 1000 ohms 1.6W on each 3. Its being supplied via a 12 V battery. The circuit is wired up to a PIR which when detects movement the LED's will light up.
I need some help working out how much current will be running throughout the circuit and its voltage drop?
I have 84 White LED's connect. Each LED being 3.4 V @ 10mA
You have a 12 volt supply and across it you have 28 strings, each containg a resistor and 3 LEDs (all white, 3.4 volt ones) in series.
The strings are in parallel. Is this all correct?
If so, then the voltage across the LEDs is 3 times 3.4 volts or 10.2 volts. So the voltage across the resistor is 1.8 volts.
The current you want, 10 mA, is flowing through this resistor, so its value must be V / I or 1.8 volts / 10 mA or 180 ohms.
LEDs usually run at a maximum of 20 mA so you could do this by making the resistor 1.8 volts / 0.02 amps or 90 ohms. You could use 100 ohms since these are easy to find. 0.25 watt resistors would be OK.
(1.8 volts times 0.02 A = 36 mW)
If your 12 volt supply is really higher than 12 volts, you should recalculate the resistor sizes to get more accurate results.
The total current would be 28 times the current through each string. So, 280 mA if it was 10 mA and 560 mA if it was 20 mA.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
