Large or small deflections of a cantilever beam
The discussion focuses on the applicability of classical bending theory for cantilever beams under various loading conditions. It highlights that Euler-Bernoulli beam theory can be used when the beam length is at least ten times its depth, while Timoshenko beam theory is recommended for shorter beams. Additionally, small deflection theory is applicable if the beam's maximum bending deflection is also within a certain ratio to its length. The conversation emphasizes the importance of selecting the appropriate beam theory to accurately model the first natural frequency of the beam. References for these parameters were requested to support the guidelines provided.
fmsrat
Hi,
I'm looking for a parameter or a design guideline that could say weather or not the classical bending theory can be applied to certain beam under certain load. I'm making my dissertation about some work on cantilever beam and it's first natural frequency, so in order to model correctly the beam i would like to know if could use the classical bending theory.
Thanks in advance
fmsrat:
From what I remember, using the classical beam theory (euler-bernoulli) does not account for shear strain which would over or under estimate your natural frequency. I feel that the beam theory you should be looking is Timoshenko.
Again, this from what I remember. Hopefully someone can correct me if I am wrong.
Best of luck.
fmsrat: (1) For a cantilever beam, you generally can use classical beam theory (Euler-Bernoulli beam theory) if beam length L ≥ 10*h, where h = beam cross-sectional depth.
(2) For a cantilever beam, if L < 10*h, you might want to use Timoshenko beam theory.
(3) For a cantilever beam, you generally can use beam small deflection theory (i.e., basic Euler-Bernoulli or Timoshenko beam theory, mentioned in items 1 and 2) if L ≥ 10*y, where y = beam maximum bending deflection.
(4) For a http://img72.imageshack.us/img72/9576/beam02.png or http://img600.imageshack.us/img600/3467/beam03.png (clamped, embedded, encased, encastre, built-in) beam, change each 10 to 20 in items 1, 2, and 3, above.
Thanks for your reply, could you tell me what references(articles,books) did you use for that parameters.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
