Purchasing Torsional Strain Gauges
  • Thread starter Thread starter RobertsSBD
    Strain
Torsional strain gauges are not a specific product; instead, strain gauges measure direct strain. For torsion in circular shafts, shear strain occurs on the surface, which can be captured using standard strain gauges positioned at 45 degrees to the axis. A strain gauge rosette, consisting of three gauges arranged 120 degrees apart, can effectively measure two-dimensional strain fields. Users seeking to measure torsional effects should consider these alternative configurations rather than looking for a specialized torsional strain gauge. Understanding these principles is essential for accurate strain measurement in engineering applications.
RobertsSBD
Does anyone know where I can purchase a torsional strain gauge? Website? Company?
Thanks
I don't think there is sich a thing as a "torsional strain gauge". Strain gauges measure direct strain. If you have torsion in a circular shaft for example, there is a shear strain on the surface of the shaft which is equivalent to equal and opposite direct strains at 45 degrees to the axis of the shaft. So you just use two "ordinary" strain gauges at 45 degrees to the axis.
A strain gauge rosette with 3 gauges 120 degrees apart will measure any two-diimensional strain field.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
