SPICE Circuit Parameter Extraction
To extract circuit parameters from experimental data, curve fitting using software like MATLAB or Python is recommended, as it allows for optimization of the equivalent circuit model. SPICE tools can also be used for parameter optimization, but familiarity with SPICE model equations is necessary. Additionally, specialized software such as Keysight's IC-CAP can facilitate the extraction of general circuit parameters. The discussion emphasizes the importance of fitting experimental data to the equivalent circuit model to derive resistance and capacitance values. Overall, various methods and tools are available for effective circuit parameter extraction.
py_engineer
Hi,
I am looking for information on how to extract circuit parameters.
I have a system, and I can experimentally perform current and voltage measurements. For example, I can measure the voltage response of the system as a function of a given input pulse.
In addition, I also have an equivalent circuit model to represent this system, composed of various resistors and capacitors.
What I don't know is the resistance and capacitance values for the elements in my equivalent circuit model.
I was wondering if there are tools, like SPICE tools, or methods to extract the circuit parameters that would fit the best my experimental data. I have a SPICE extraction tool, however it is designed to extract transistor parameters. I can't find tools that can extract general circuit parameters. I am not sure that I am being very clear, so please let me know if this is confusing, and if you have suggestions on tools and methods.
Thanks a lot!
If your circuit is all passive, you can get equivalent circuit components by measuring resistance and inductance/capacitance.
Hi,
Thanks for your answer. My system is a black box, so I can't just go and measure the resistances and capacitances. I have an equivalent circuit model for my system, and I can obtain experimental data from the system, so I am just looking for a tool that will fit the equivalent circuit model to the experimental data.
If you have experimental data, then you can use Matlab/Origin etc. to curve fit on the data using a custom defined curve. If you want to fit it in SPICE model the work is same. However, you have to know the SPICE model equations which will be used for fitting.
Hello,
Thank you for reaching out about your question on SPICE circuit parameter extraction. There are indeed tools and methods that can help you extract circuit parameters from your experimental data and equivalent circuit model.
One method is called curve fitting, where you can use software such as MATLAB or Python to fit your experimental data to your equivalent circuit model and extract the parameters that best fit the data. Another method is called optimization, where you can use software such as SPICE or LTSPICE to optimize the circuit parameters to match your experimental data.
In addition to these methods, there are also specific tools designed for circuit parameter extraction, such as Keysight's IC-CAP software. This tool allows you to extract general circuit parameters from your experimental data and equivalent circuit model.
I hope this helps answer your question and provides some options for you to consider. Let me know if you have any further questions or need additional clarification.
Best,
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
