Find the rms speed of a dust particle.
The discussion centers on calculating the root mean square (rms) speed of a dust particle, given its diameter of 13.0 micrometers and density of 2540 kg/m3. The user correctly converts the diameter to radius and calculates the volume of the particle using the formula for a sphere. They then determine the mass of the dust particle but express uncertainty about the final rms speed calculation, suspecting an error. The user seeks assistance in identifying any mistakes, particularly in the volume calculation. The conversation highlights the importance of accurate volume and mass calculations in determining the rms speed of particles treated as ideal gases.
nlingraham
Dust particles are 13.0 micrometers in diameter. They are pulverized rock, with ρ=2540 kg/m3 . If you treat dust as an ideal gas, what is the rms speed of a dust particle at 18.0 C?
ρ=m/v
V=4/3∏r2
vrms=√(3kT/m)
OK:
13 micrometers = 1.3*10-5 m, which makes radius 6.5*10-6 m
Then, V=(4/3)∏(6.5*10-6)2=1.7697*10-10 m3
m=ρv=(2540)(1.7697*10-10 m3)=4.495*10-7 kg
vrms=√(3*(1.38*10-23)*(273+18))/(4.495*10-7 kg))
=1.63*10-7 m/s
This isn't right though, anyone see where I went wrong?
Check the volume of a sphere.
Thank you very much
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
