Taking the integral of a series
  • Thread starter Thread starter Guidenable
    Series Sum
The forum discussion centers on finding the exact sum of the series \(\sum \frac{2}{n7^n}\) from \(n=1\) to \(\infty\). Participants discuss the incorrect application of logarithmic properties in the initial attempts, specifically the misinterpretation of \(\ln(a+b)\) as \(\ln a + \ln b\). The correct approach involves recognizing the relationship between power series and integrals, emphasizing the importance of uniform convergence for interchanging summation and integration. Ultimately, the discussion highlights the necessity of proper mathematical justification when manipulating series and integrals.
  • Understanding of infinite series and convergence
  • Familiarity with logarithmic properties and their applications
  • Knowledge of power series and their manipulation
  • Basic calculus concepts, particularly integration techniques
  • Study the properties of power series and their convergence criteria
  • Learn about the integral test for convergence of series
  • Explore the relationship between series and integrals in calculus
  • Investigate uniform convergence and its implications for series manipulation
Mathematics students, educators, and anyone interested in advanced calculus concepts, particularly those dealing with series and integrals.
Guidenable
Find the exact sum of:
\sum 2/(n7n)
n=1->∞
Let Sn denote the nth partial sum.
ln(Sn) = \Sigma ln(2/(n7n))
=\Sigma ln2 - lnn - nln7
= nln2 - (ln1 + ln7 + ln2 + 2ln7 + ln3 + 3ln7 ...)
= nln2 - ln(n!) - ln7\Sigma n
= ln (2n)/n! - ln7 (\Sigma n)
I'm not sure where to go from here, or if I'm even going in the right direction.
Do you know how these two power series relate to each other?
\sum z^{n-1}
\sum \frac{1}{n} z^n
No, but now I intend to find out. A hint would be appreciated though.
Never mind. Those two series are related by a factor of 1/zn. I should have looked a bit closer :/.
Hint: \int z^{n-1} dz = \frac{1}{n} z^n
\sum 2/(n7n)
n=1->∞
This approach won't work because the very first step is wrong. It's not true that ln(a+b) = ln a + ln b.
\sum 2/(n7n)
n=1->∞
Stop right there. What you have done is invalid: the log of a sum is not the sum of the logs. For example, if you claim that log(2 + 3) = log(2) + log(3) you would have log(2) + log(3) = log(2*3) = 6 (because the log of a product is the sum of the logs), so your method would give log(5) = log(6), hence 5 = 6.
RGV
Thanks for the correction, I normally know log rules, just that one slipped. You guys mean bringing the log into the sum, right?
So I just evaluate the integral?
Yes, do you see how this can be applied to this problem?
I thought that was what I said.
RGV
Yes, I understand now, thank you very much!
Hey I was just wondering how you can take the integral of a series to find the sum? Don't series only include integers and will not add up to the same thing as a integral? For example my calculus textbook says when doing the integral test specifically states that the integral is not the sum of the series. Can someone please tell me what I am missing? Thank you.
If
f(z) = \sum a_n z^n
then, under certain conditions, you can perform manipulations like this:
\int f(z) dz = \int \sum a_n z^n dz = \sum \int a_n z^n dz = \sum \frac{a_n}{n+1} z^{n+1} dz
You need to provide justification for interchanging the order of integration and summation. Uniform convergence of the power series is a sufficient condition.
This kind of trick is useful for finding sums such as \sum (a_n / n) z^n, provided you have a closed-form expression for \sum a_n z^n. Term by term differentiation of the power series can also be useful in some situations.
The idea here is to recognize that some fairly well-known power series in x (or z as jbunniii seems to like) is involved here, and that this power series represents a function of x. Then plug-in a value for x which gives the series of interest in this problem.
  • · Replies 22 ·
9K
