Calculate Magnitude of Moment in 3D
The problem involves calculating the moment about point O due to a force acting on point A, with a tension of 1.5 kN in cable AB. The coordinates for points A and B were established, and the unit vector for AB was calculated. An initial miscalculation in the dot product led to an incorrect moment value. After correcting the dot product, the cross product yielded the correct moment magnitude of 3.58. The discussion highlights the importance of accurate calculations in vector operations for solving 3D mechanics problems.
Northbysouth
The turnbuckle is tightened until the tension in cable AB is 1.5 kN. Calculate the magnitude of the moment about point O of the force acting on point A.
ƩMO = sqrt(Mx2 + My2 + M2)
First I identified the coordinates of points A and B:
A = (1.6, 0, 2.4)
B = (2.3, 1.4, 0)
OA = r = <1.6, 1.4, 0>
AB = <0.7, 1.4, -2.4>
|AB| = 2.865
λAB = AB/|AB|
λAB = 0,2443i + 0.4877j - 0.8377k
Then I took the dot product with the tension in the cable AB and the unit vector of AB
TABAB = 0.36645i + 0.73305J - 1.25655K
ƩMO = rXTAB
(0-1.75932)i -(-2.81796)J + (1.17288)k
ƩMO = 3.523
But it says my answer is wrong and I don't know where I'm going wrong.
Suggestions would be appreciated
I've just checked my working and found that I miscalculated the dot product.
<1.6, 0, 2.4> X <0.36645, 0.73305, -1.25655>
= -1.75932i + 2.88996J + 1.17288K
When I take the magnitude of this I get 3.58 which is the correct answer.
