Simplifying slope-angular acceleration vs torque
The discussion centers on the relationship between angular acceleration and torque, highlighting a positive linear correlation observed in a lab experiment. The main challenge is simplifying the units of slope in terms of kilograms, meters, and seconds. The participant is attempting to derive the equation relating angular acceleration to torque and inertia but struggles with unit simplification. Clarifications are provided regarding the correct dimensional analysis, particularly addressing a miscalculation involving the units of angular acceleration. Ultimately, the focus remains on accurately expressing the relationship between these physical quantities.
pentwaterwave
In a lab we conducted in class we graphed angular acceleration vs torque, and found a positive linear correlation-easy enough. However I am getting rather stuck in simplifying the units of slope in terms of Kg, m, and s... I am fairly sure this will give me that angular acceleration equals torque times inertia but I have trouble with simplifying the slope AND with even getting torque and angular acceleration simplified to kg m and s. I would really appreciate some help! thanks!
Torque=NM
NM=Kg*a*m
kg*a*m=kg*(m/s^2)*m
=kg*m^2/s^2
Angular Acceleration= rad/s^2
rad/s^2=at/r
at/r=m/s^2/r
m^2/s^2
(kg*m^2/s^2)/(m^2/s^2)
=kg
Torque=NM
NM=Kg*a*m
kg*a*m=kg*(m/s^2)*m
=kg*m^2/s^2
rad/s^2=at/r
at/r=m/s^2/r
m^2/s^2
Your mistake is here. You have
$$\left[\frac{a_t}{r}\right] = \frac{\text{m}/\text{s}^2}{\text{m}} = \cdots$$ You shouldn't get m2/s2.
=kg
