Using Cauchy integral formula to compute real integral?
Mixer
Compute the following integral around the path S using Cauchys integral formula for derivatives:
\intez / z2
Integral path S is a basic circle around origin.
Then, use the result to compute the following integral
\int ecos (x) cos(sin (x) - x) dx from 0 to ∏
Cauchy integral formula: http://en.wikipedia.org/wiki/Cauchy's_integral_formula
I was able to compute the first part and got 4∏i. But I'm stuck in second part. How I'm supposed to use the result I got in first part to compute the second? Any hint for me?
\intez / z2
Well, you know \cos(a-b)=\cos(a)\cos(b)+\sin(a)\sin(b) and you got \cos(a-b) in there. Ok, keep that in mind.
Now, what do you get when you let z=e^{it} in the expression:
\int \frac{e^z}{z^2}dz
and then split the integral into a real and imaginary part?
Hint 1: \int_{\gamma} f(z) dz = \int^b_a f( \gamma(t) ) \gamma'(t) dt.
Hint 2: \cos(\sin x - x) = \operatorname{Re} e^{i\sin x - ix}.
Thank you very much!
I actually had a typo in my first post. So the integral I'm supposed to compute is
\inte2 cos (t)cos(sin(t) - t) dt from 0 to ∏
I was, however, able to compute the integral you gave me to this kind of form (this is an imaginary part of the integral:
\inte2 cos (t) cos (sin(t) - t) dt from 0 to 2∏
is equal to 4∏ (the result I got in first part)
Now, how can I get the correct value when integrating from 0 to ∏ ?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
