Kinematics - Finding velocity of a baseball
A baseball player hits a ball that lands 24 meters above the field at a velocity of 50 m/s at a 35-degree angle below the horizontal. To find the initial velocity when hit from 1 meter above the field, calculations show it to be approximately 50.61 m/s. The horizontal distance traveled by the ball is calculated to be around 235 meters. The time the ball is in the air is determined to be approximately 5.74 seconds. The discussion emphasizes using kinematic equations to solve for velocity, distance, and time in projectile motion scenarios.
kidia
Hi I have a question
A baseball player hits a baseball that lands in stands 24 meters above the playing field.The ball land with velocity of 50 meters per second at angle of 35 degree below the horizontal.
a.If a player hits the ball 1 meter above the playing field,what was the velocity of the ball upon leaving the bat?
b.What was the horizontal distance traveled by ball
c.how long was the ball in air
I have done like this:
let r be angle in degrees
t=2usinr/g
time=?
velocity=50m/s
gravity=10
time= 2*50*sin35/10=5.74s
velocty of ball at 1m will be:
y=vsinrt-0.5gt
1=usin35*5.74-0.5*10*5.74*5.74
u=50.61m/s
b.horizontal distance traveled by ball
distance/time=velocity
then
distance/time=ucosr
distance=50cos35*5.74
distance=235m
c.Time of the ball in air.
t=2usinr/g
time=?
unitial velocity=50m/s
gravity=10
Any idea about this question?
Let the horizontal and vertical components of the initial velocity be u_1, u_2
Apply v^2 = u^2 + 2fS in vertical and horizonatal directions to find u1 and u2.
Note that the vertical distance traveled is 24 -1 = 23 m.
So inital velocity = \sqrt {(u_1^2 + u_2 ^2)}
(2). Apply v = u + ft vertically to find the time of travell
(3) Apply s = ut + \frac{1}{2} f t^2 horizontally to find the distance travelled.
Ooo is fine but my doubt is about the angle 35 degees u didn't mention it
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
