Attractive force between Venus and Sun
  • Thread starter Thread starter sadifermi
    Force Sun Venus
The discussion centers on calculating the gravitational force between Venus and the Sun using the formula F = Gm1m2/d^2. The calculated force is approximately 5.4687 x 10^22, but participants note that it should be rounded to three significant figures, resulting in 5.47 x 10^22 N. There is also mention of discrepancies with values from WolframAlpha, which uses slightly different mass figures for Venus and the Sun, yielding a force of 5.54 x 10^22 N. Additionally, the importance of including units in the final answer is emphasized. Accurate rounding and unit inclusion are critical for clarity in scientific calculations.
sadifermi
I just need someone to double check my answer and confirm they get the same answer as I do. Thanks.
Question: Find the attractive force between Vneus and the sun. The distance between their centers is 1.08x10^11.
Equation: F = Gm1m2/d^2
G= 6.67x10^-11 N.m^2/kg^2
m1 (mass of sun)= (1.98x10^30kg)
m2 (mass of venus) = (4.83x10^24kg)
d= (1.08x10^11)
= (6.67x10^-11 N.m^2/kg^2)(1.98x10^30kg)(4.83x10^24kg)/(1.08x10^11)^2
=5.4687 x 10^22
Please let me know if this is the correct answer asap. Thanks!
Your answer has no units.
d= (1.08x10^11)
=5.4687 x 10^22
You have just omitted the next digits rather than round off to the 5 figures you have chosen to specify.
besides, your answer should only be to 3 figures!
And as per the previous post - you need some units.
Thanks folks, appreciate it!
WolframAlpha gets a slightly different result: 5.54*10^22 N
It uses a mass of venus which is larger by 1% and a mass of sun which is larger by .5%.
So you should have been saying 5.47 (correctly rounded) not 5.46 (merely truncated)
