Solving for a force eliminating acceleration
  • Thread starter Thread starter cwbullivant
    Acceleration Force
A worker applies a force of 210N to a box on a cart, which moves as one unit due to friction. The discussion centers on understanding how to eliminate acceleration (A) from two simultaneous equations derived from free-body diagrams of the box and cart. The key equation derived is FCB = (Mcart*FBW)/(Mcart+Mbox), which simplifies the problem by substituting values and eliminating A. Clarification was provided that "eliminating A" means solving for A in one equation and substituting it into the other. The conversation highlights common struggles in physics problem-solving and the importance of clear communication in understanding concepts.
cwbullivant
A worker applies a force of 210N to a box attached to a cart, with sufficient frictional force such that the box and the cart move as one. What is the frictional force on the box?
Force 1: Force on box by worker, FBW
Force 2: Force on cart by box, FCB
Force 3: Force on box by cart, FBC
This is from the solution, but I can't understand how it was obtained, as it doesn't explain the process:
FCB = McartA (I knew this part)
FBW - FBC = MboxA
"Since we want to solve for the unknown FCB = FBC, we eliminate A from these two equations and obtain:"
I don't quite understand what they mean by "eliminate A" (hold it constant?), nor can I seem to deduce the process they used here.
I've tried substituting in McartA for FBC (since they're equal), but all that does is solve for A, which I'm evidently supposed to eliminate to begin with.
They have started by drawing free-body diagrams for the box and the cart, then, for each diagram, summed the forces and used Newton's law.
This gives two simultanious equations and two unknowns ... how would you solve them?
Then mean that you solve for A in one equation and substitute it into the other one.
The first became immediately obvious when I read the second. I feel really, -really- dumb right now; I really have no excuse for not getting that. Thanks for the help, much appreciated.
We all do that from time to time - sometimes a change in wording can make the mind go blank.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
