Prove the BAC CAB Rule: Ax(BxC)=B(A.C)-C(A.B)
  • Thread starter Thread starter shaiqbashir
6 replies · 42K views
shaiqbashir
Hi!
Please can u prove the following rule!
this is usually remembered as "BAC CAB Rule"
i just couldn't solve this question.
Thanks in advance
Tedious, but straightforward is just writing out the components.
Try verifying the equation one component a time.
For example, the x-component of A X (B X C) is:
[tex]A_y(B_xC_y-B_yC_x)-A_z(B_zC_x-B_xC_z)[/tex]
, which can be rewritten as:
[tex]B_x(A_yC_y+A_zC_z)-C_x(A_yB_y+A_zB_z)[/tex]
you almost have the x component of B(AC) in the left term and the x-component of C(AB) in the right term. They both miss the same term [itex]B_x(A_xC_x)[/itex] so you can just add it to both terms, since they will cancel. This establishes the relation for the x-component. Do the same for the other two (or try to be smart and use some symmetry argument).
Well thanks for ur reply but can u please tell me in some more detail so that i can understand it more properly!
Thanks!
I`m not sure which part is unclear to you.
What I meant was:
is true if and only if all three components for the vector on the left and on the right are equal. Equating one component a time makes it less cluttery.
Let:
[tex]\vec A = A_x \vec i + A_y \vec j + A_z \vec k[/tex]
[tex]\vec B = B_x \vec i + B_y \vec j + B_z \vec k[/tex]
[tex]\vec C = C_x \vec i + C_y \vec j + C_z \vec k[/tex]
Let D = B x C:
The expression for B x C is:
[tex]\vec D = (B_yC_z-B_zC_y)\vec i + (B_zC_x-B_xC_z)\vec j +(B_xC_y-B_yC_x)\vec k[/tex]
The x-component of A x D is:
[tex]A_yD_z-A_yD_x[/tex]
The components of D can be gotten from the expression from B x C, so:
[tex](\vec A \times \vec D)_x = A_yD_z-A_zD_y=A_y(B_xC_y-B_yC_x)-A_z(B_zC_x-B_xC_z)[/tex]
[tex]=B_x(A_yC_y+A_zC_z)-C_x(A_yB_y+A_zB_z)=[/tex]
[tex]B_x(A_xC_x+A_yC_y+A_zC_z)-C_x(A_xB_x+A_yB_y+A_zB_z)=\left[\vec B (\vec A \cdot \vec C)-\vec C(\vec A \cdot \vec B)\right]_x[/tex]
Thank u very much Galileo but would u please explain ur last step for me that how u convert the 2nd last step to the last step.
PLzzzzzzzzzzzzzzzzzzzz
Thanks a lot again
