Finding a Dynamics Book with Derivation for Angular Acceleration
  • Thread starter Thread starter jehan60188
    Book Dynamics
In an undergraduate dynamics class, the professor utilized tensors and made assumptions that led to the derivation of equations for angular acceleration, highlighting the instability of rotation in certain scenarios. The textbook by Johnston and Beer lacks derivations, prompting the search for a more comprehensive resource. Suggestions include looking for a 400-level or graduate-level text that provides detailed derivations. "Analytical Dynamics" by Baruh is recommended as a potential supplement. The discussion emphasizes the need for a deeper understanding of angular acceleration through rigorous derivation.
jehan60188
in an undergrad introductory dynamics class, my professor used tensors, and assumed things went to zero to derive equations for angular acceleration.
he then proceeded to show how a rotating body with certain moments of inertia will experience unstable rotation about certain axes due to the previously mentioned assumption not being valid
johnston and beer do not cover this, they merely spit out equations with no derivation
is there a better book? perhaps a 400 level text, or even graduate level text that I can look at to get this derivation?
thanks!
I used "Analytical Dynamics" by Baruh to supplement my textbook in one of my graduate classes. It may have what you are looking for.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
