Neutral wire position - Distribution system
The discussion centers on the positioning of neutral wires in distribution systems, specifically the advantages and disadvantages of placing the neutral wire either on top of or high above phase conductors. Positioning the neutral wire on top can enhance system stability and performance but increases the risk of contact with phase conductors, posing safety hazards. Conversely, placing the neutral wire high above improves safety and fault detection but may result in greater voltage drops and reduced efficiency. The choice between these configurations should consider safety, efficiency, and maintenance needs, guided by relevant standards and utility company guidelines. Ultimately, a thorough evaluation of the specific distribution system is crucial for optimal neutral wire placement.
Foxh0und
looking for standards & guidelines on Neutral Wire for distribution system, especially Neutral Up or Neutral High (neutral on top of the phase conductors), advantages & dis-advantages of it.
Welcome to the PF.
Do you mean standards like the National Electric Code (NEC)? What kind of distribution systems are you referring to?
what i means is manual & guidelines of utility companies regarding the moutning of distribution neutral wires.
Old lineman told me:
Neutral above acts as a lightning rod, helps keep it out of the phases.
Neutral below allows shorter poles.
Observe that large transmission lines are usually the former, obviously that helps system reliability. Local distribution at lower voltage is often the latter. I lived in a high lightning part of the country where most neutrals were above.
old jim
I understand the importance of having standards and guidelines in the distribution system to ensure safe and efficient operation. In regards to the neutral wire position, there are various factors that need to be considered when deciding whether to have the neutral wire located on top of the phase conductors (neutral up) or high above them (neutral high).
One advantage of having the neutral wire positioned on top of the phase conductors is that it can provide better balance and stability to the distribution system. This is because the neutral wire is located closer to the phase conductors, which can help reduce the voltage drop and improve the overall performance of the system. Additionally, having the neutral wire up can also make it easier to access and maintain, as it is more visible and less likely to be obstructed by other components.
However, there are also some disadvantages to having the neutral wire up. One potential issue is the increased risk of contact with the phase conductors, which can be dangerous for workers and the general public. This can also lead to power outages and damage to equipment if the neutral wire comes into contact with the phase conductors. Furthermore, having the neutral wire up can also make it more challenging to detect and repair faults in the system, as the neutral wire may be hidden or harder to access.
On the other hand, having the neutral wire located high above the phase conductors can offer some advantages. One major benefit is the increased safety as it reduces the risk of contact with the phase conductors. This can also make it easier to identify and repair faults in the system, as the neutral wire is more visible and accessible. Additionally, having the neutral wire high can help reduce the risk of damage to the neutral wire from animals or vegetation.
However, there are also some drawbacks to having the neutral wire high. One potential issue is an increased voltage drop, as the distance between the neutral wire and the phase conductors is greater. This can lead to a decrease in the efficiency and performance of the distribution system. Additionally, having the neutral wire high can make it more challenging to access and maintain, as it may require specialized equipment or additional safety measures.
In conclusion, the decision of whether to have the neutral wire positioned up or high in the distribution system should be based on a thorough evaluation of the specific system and its needs. It is essential to consider factors such as safety, efficiency, and ease of maintenance when determining the best location for the neutral wire. Standards and guidelines can also provide
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
