Archived How Can You Calculate the Wavelength in a Double Slit Experiment?
To calculate the wavelength in a double slit experiment, the relevant equations involve the distances between maxima and the slit separation. Given the angle to the eighth maximum, the distance from the slits to the screen, and the distance between slits, the wavelength can be derived. By using the provided data, specifically the distance between the fifth and first minima, the wavelength is calculated to be 610 nm. Additionally, using the angle to the eighth maximum also confirms the wavelength as 610 nm. This demonstrates that both methods yield consistent results for the wavelength.
quicksilver123
The following data was obtained via the double slit experiment:
angle to the eighth maximum = 1.12 degrees
distance from slits to screen = 302cm = 3.02m
distance from first to fifth mimum = 2.95cm
distance between slits = 0.00025m
find the wavelength.
supposed to use this equation to find wavelength:
xn/L=(n-0.5)(\lambda/d)
or
xm/L=(m)(\lambda/d)
problem is, there's no given value for xm or xn
how can i get this value?
(oh, and i specifically have to use the equation listed above)
##x_m## is the distance off axis of the mth maximum, numbering the central bright spot as ##m=0##. You can immediately write the distance between the Mth and mth maxima as ##x_M-x_m=(M-m)L\lambda/d##. A little manipulation gets you ##\lambda=d (x_M-x_m)/L (M-m)##. You provided the distance between the M=5 and m=1 maxima. Plugging that and your other data in gets you ##\lambda=610##nm.
You also gave the angle to the 8th maximum, which tells us that the distance from the axis to the 8th maximum is 3.02 sin(1.12)=0.059m. Plugging that in with M=8, m=0 also yields 610nm.
