Understanding the Path of Radio Waves (particularly 900 MHz & 2.4 GHz)
Understanding radio wave propagation, particularly for 900 MHz and 2.4 GHz, involves recognizing how waves interact with various materials, including absorption by metal and water, and reflection off surfaces. The ability to predict whether waves will reflect or pass through objects depends on the material properties, which can be modeled using electromagnetic theory, though real-world applications are complicated due to numerous obstacles. Approximate models, like the COST 231 model, are often used to estimate propagation in different environments, such as urban or rural settings. Multipath fading occurs when multiple waves interfere due to reflections, leading to time-varying signal quality in mobile communications. For practical applications, using propagation prediction software is recommended for accurate assessments.
Underhill
I'm interested in how to understand exactly how radio waves will propagate in a particular situation. I know that they are absorbed by metal and water, pass through other materials albeit with loss of power, and reflect or bounce off of surfaces as well.
How do I know whether a radio wave will reflect off of something or not? How do I know, for either a LOS or NLOS link, how much of the waves that reach the target have (1) reflected off of surfaces or (2) traveled straight through the air or (3) traveled straight through objects (e.g., walls)?
I am specifically interested in the propagation of 900 MHz and 2.4 GHz radio waves.
(Or should this question be posted in a Physics forum?)
This is a complicated subject. It is possible to model transmission through a material, and reflections from it, using electromagnetic theory--if you know the material properties (complex permitivity, and magnetic permeability). Diffraction around edges is also important, and much harder to solve for exactly. In the real world, such modeling is nearly impossible due to the huge number of surfaces (buildings, hills, roads) and other obstacles such as trees.
As a result, approximate models geared toward the general environment (rural, suburban or urban) are used. One of the most common is the COST 231 model, but you can search on "mobile propagation channel models" to find many more.
A result of reflections is multipath fading--that is, multiple waves traveling different path lengths interfere constructively and destructively. For mobile communications, the result is time-varying signal fading. You can search Rayleigh fading and Rician fading to learn more.
Unless you are working on a thesis or dissertation your best bet would be to find a propagation prediction program. Have you done any internet searches for propagation prediction software?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
