Magnetic field induced by time-dependent current through out space?
liumylife
There's a infinitely-long straight line in vacuum goes through space, carrying a current which is time-dependent. What is the magnetic field induced by the curent?
B, vector, the magnetic field
E, vector, the electric field
J, vector, the current density
ρ, scalar, the charge density
t, time
μ0, permeability
ε0, permitivity
div, divergence ( of vector )
rot, curl or rotation ( of vector )
Δ, Laplacian operator
t, partial differential operator with respect to time
r^, θ^ and z^ are unit vectors of r, θ, z
Maxwell's equations in vacuum:
div E = ρ / ε0
rot E = -∂t B
div B = 0
rot B = μ0 J + μ0ε0t E
Continuum equation:
div J = -∂t ρ
Take the straight line as z axis, using cylindrical coordinate r, θ, z.
The current density should be J = I(t) δ(r) z^ where the I(t) is the current intensity changing with time, and δ(r) is 2-D Dirac delta function.
Taking the rotation of the last equation in M's equations, I have
-Δ B = μ0 rot J - (∂t)2 B,
the rot J term brings trouble, what do I get when differentiate delta funtion?
I would use the given current density to determine the vector potential \vec A
which is related to the B and E fields by:
\vec B = \nabla \times \vec A\vec E = - \frac{\partial \vec A}{\partial t}- \vec \nabla \phi
After the gauge choice div A = 0 i got after omitting constants, like c:
\square \vec A = \vec j + \vec \nabla (\nabla \vec j)
Write this out in your coordinate choice.
I think this can be solved easily for A using Green's functions and doing a Fourier transform. I haven't tried it out myself yet.
If anyone knows a better way, have at it, I'm interested as well.
Solution
I found the solution in Griffiths' book: Chap.10, (10.31), generalization of the Biot-Savart law.
Looks like a tough inegration to find A . Easy for a short wire, L << λ or r, but for an infinitely long one?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
