Isentropic Relations for Real Gas in Converging-Diverging nozzle
The discussion focuses on calculating the maximum flow rate through a converging-diverging nozzle for a non-ideal gas. The isentropic assumption is considered, where stagnation enthalpy remains constant, and the user plans to utilize thermodynamic properties from 'refprop' for calculations. The isentropic pressure-temperature relation is questioned regarding its applicability to non-ideal gases. It is suggested that an equation of state for the real gas could provide equivalent isentropic relations, or a polynomial approximation might be used. Computational methods are also mentioned as an alternative if analytical approaches are insufficient.
Jonny6001
Hello,
I am looking at a problem concerning flow through a converging-diverging nozzle. The governing equations are relatively straight-forward for gasses that closely follow the ideal gas law. However I am looking at an unusual gas which is certainly not represented by the ideal gas assumption.
I am curious how you would go about calculating the maximum flow rate through the nozzle when the flow is choked at the throat, I do not want to use CFD initially.
My first thoughts would be to use the isentropic assumption that the stagnation enthalpy is constant throughout the nozzle. From having access to thermodynamic properties of the gas via 'refprop' it should be possible to iterate the temperature in the nozzle to achieve the same stagnation enthalpy as the inlet conditions. But the enthalpy is also dependent on the pressure so I thought I could use the isentropic pressure-temperature relation to couple the pressure to the temperature so that everything at the throat would be defined from knowing the temperature. But it using the isentropic law P0/P1=(T0/T1)^(gamma-1/gamma) assuming that the gas behaves according to the ideal gas law?
Thank you
Yes, the typical isentropic relations - p/p_0 = (\rho_\rho_0)^{\gamma} = (T/T_0)^{\gamma/(\gamma-1)} - directly follow from the equation of state for an ideal gas. If you had an equation of state for your real gas you could likely come up with an equivalent set of isentropic relations for your real gas. Otherwise, you may be able to approximate it with a polynomial. The only other option beyond that would be to do it computationally.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
