Is the effective aperture of an antenna a constant?
  • Thread starter Thread starter yungman
    Antenna Constant
The effective aperture of an antenna is calculated using the equation A_{eff} = D_0(λ^2/4π), assuming matching polarization and output impedance for maximum power transfer. In contrast, Balanis' formulation incorporates additional loss factors, including ohmic loss and load matching, indicating that the effective area is influenced by polarization and external parameters. The first equation assumes no losses, while the second accounts for radiation efficiency, which combines various losses. Another common representation is A_{eff} = G(λ^2/4π), where G represents antenna gain, defined as G = ηD, with η being radiation efficiency. This highlights the importance of considering losses when evaluating antenna performance.
yungman
When finding the effective aperture of an antenna we use:
A_{eff}\;=\;D_0\frac{\lambda^2}{4\pi}\;\hbox{ where }\;\frac{\lambda^2}{4\pi}\;\hbox { is the effective aperture of a isotropic antenna.}
I read from Wikipedia and other sources that in order to use this equation, you assume the polarization of the incident wave matches the receiving antenna. AND the output impedance of the receiving antenna is conjugate match to the load for maximum power transfer.
But in the Antenna Theory book by Balanis:
A_{eff}\;=\;e_0|\hat{\rho_w}\cdot\hat{\rho_a}|^2 D_0\frac{\lambda^2}{4\pi}\;\hbox { where }\; e_0=e_{cd}(1-|\Gamma|^2)
##e_{cd}## is the ohmic loss, ##(1-|\Gamma|^2)## is the load matching loss, and ##|\hat{\rho_w}\cdot\hat{\rho_a}|^2## is the polarization loss factor.
Balanis includes all the loss factors to calculate the effective area. This implies the effective area of the receiving antenna depends on the polarization of the incident TEM wave AND the load matching. This means the effective area varies with other outside parameters. I don't think that is correct. Please give me your thoughts.
Thanks
First equation (assuming D0 is directivity) assumes no losses.
Second equation includes all of the losses which are often combined into "radiation efficiency".
Another way this is commonly written:
A_{eff}\;=\;G\frac{\lambda^2}{4\pi};
Where G is the antenna gain.
G = ηD Where:
D is the directivity.
η is the radiation efficiency and includes all of the losses (resistive, mismatch etc).
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
