Mechanics Problem: Finding the speed at the center of a ring
morrisj753
A homogeneous ring lays horizontally on two identical parallel rails. The first rail moves parallel to itself, with a constant speed v; the second rail is at rest. The angular distance between the ring-rail contact points, as seen from the center of the ring, is 2α for the first rail, and 2β for the second rail, see figure. Assuming that α << 1 and β = π/3, find the speed of the center of the ring.
(and also, the first rail intersects the ring at two points)
τ (torque) = F x r
I wasn't quite sure where to start but I thought I might be able to use a torque balance to find the frictional forces, though I'm not sure where to go from there, or whether I am actually taking the correct approach.
That looks like a good idea.
Afterwards, you can consider rotation around a different axis to get the speed (and angular velocity) of the ring.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
