Proving that a heat engine cannot exceed the carnot efficiency
The discussion centers on the theoretical implications of connecting a super-efficient heat engine with an efficiency of 60% to a refrigerator with a coefficient of performance (COP) of 0.5, between temperatures TH = 600 K and TL = 300 K. It highlights that this setup seemingly allows for spontaneous heat transfer from a cold reservoir to a hot reservoir, which contradicts the second law of thermodynamics. The calculations show that the work produced by the heat engine exceeds the energy needed to return heat to the hot reservoir, resulting in a net heat flow from cold to hot. However, it is pointed out that a heat engine with such efficiency cannot exist under these conditions, and the assumptions made violate thermodynamic principles. Ultimately, the scenario illustrates the impossibility of achieving a net heat transfer that defies established laws of thermodynamics.
handsomecat
In many textbooks, a proof is provided where the work output of a super-efficient heat engine is provided to a carnot refrigerator, with the net result that a spontaneous heat transfer occurs from the cold reservoir to a hot reservoir.
Let's use some numbers, TH = 600 K and TL = 300 K, so that means the carnot efficiency is 50% and the carnot COP is 1.
Between these temperatures, By connecting a heat engine of efficiency 60% to the carnot fridge of COP = 1, then one can show that the impossible occurs.
But, between these temperatures (TH = 600 K and TL = 300K) what if we connect a super-efficient heat engine of efficiency 60% to a fridge of COP = 0.5?
Though a super-efficient heat engine can't exist, coupling the two together gives a net heat transfer from the hot reservoir to the cold reservoir, which could occur. What is wrong with this line of argument?
Science news on Phys.org
You end up with more mechanical work output from the heat engine than is needed to simply return the original Qh. If you use that excess mechanical work to move more heat from the cold reservoir you end up moving more than Qh heat back to the hot reservoir.
For the heat engine: W/Qh = (Qh-Qc)/Qh = .6; ∴W=.6Qh
For the reverse cycle: Qc/W = Qc/(Qh-Qc) = Tc/(Th-Tc) = 300/(600-300) = 1; ∴W = Qc'; Qh' = W + Qc' = 2W
So let the heat engine produce W = .6Qh of work. This results in .4Qh flowing to the cold reservoir.
Then use that work to move heat back to the hot reservoir: Qh' = 2W = 1.2Qh. This consists of .6Qh coming from the cold reservoir and .6Qh from the work produced from the heat engine. So there is .2Qh more heatflow (.6Qh - .4Qh) out of the cold reservoir than the heat flow into the reservoir.
So there is a net heat flow from cold to hot with no work being added to the system (all work is generated from the heat flow within the system).
AM
Likes 1 person
I think you mean COP of 2.
Plug the numbers into the efficiency equations. You'll see that a 60% efficient heat engine and COP 2.0 refrigerator don't operate at the same temperatures.
What you are trying to do is see if a heat engine of efficiency greater than (Th-Tc)/Th violates the second law.
You could simply not run the reverse cycle at all and have a net flow of heat to the cold reservoir. But that would prove nothing.
AM
