Cross-section for elastic scattering?
muppet
Hi All,
Following on from the last dumb question I asked...
Suppose you calculate the tree-level approximation to the elastic scattering of two charged fermions
to find that the result varies as ##\sim 1/t##, where t is the Mandelstam variable describing the squared momentum transfer in the centre of mass frame.
To work out the corresponding cross-section, you integrate the square modulus of this over t with t=0 as one of your limits of integration, so that the result diverges. Why is this not regarded as a problem?
This is regarded as a problem, a socalled collinear singularity. It always occurs for theories with massless particles exchanged in the t and u channels. The cure is a resummation in this channel. Look at Weinberg, Quantum Theory of Fields, Vol. I. There's a whole chapter is devoted to infrared problems.
Thanks for your reply. I've heard of collinear singularities, but I'd always had the impression that such singularities canceled other divergences from the same order in perturbation theory- e.g. infrared divergences in loop integrals being canceled by those from bremstrahlung, so I couldn't see how such higher-order terms would cancel a tree-level effect. Guess I need to look into Weinberg, thanks.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In her YouTube video Bell’s Theorem Experiments on Entangled Photons, Dr. Fugate shows how polarization-entangled photons violate Bell’s inequality. In this Insight, I will use quantum information theory to explain why such entangled photon-polarization qubits violate the version of Bell’s inequality due to John Clauser, Michael Horne, Abner Shimony, and Richard Holt known as the...
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I asked a question related to a table levitating but I am going to try to be specific about my question after one of the forum mentors stated I should make my question more specific (although I'm still not sure why one couldn't have asked if a table levitating is possible according to physics). Specifically, I am interested in knowing how much justification we have for an extreme low probability thermal fluctuation that results in a "miraculous" event compared to, say, a dice roll. Does a...
