How can i calculate pressure drop in air compressor?
To calculate pressure drop in an air compressor system, the flow regime must be considered, with incompressible flow equations like Darcy-Weisbach applicable when air velocity is below 0.3 Mach. For velocities exceeding this threshold, compressible flow analysis is necessary. The Crane Technical Paper 410 provides guidance on compressible flows, which can be useful for air and gas systems. A formula from the Atlas Copco manual can also be employed for calculating pressure drop, factoring in air flow, pipe diameter, length, and initial pressure. In the given example, the calculated velocity is 22.08 m/s, indicating that incompressible flow equations can be used for this scenario.
noname91
hi friends,
I am confused with incompressible and compressible flow.Can i use moody diagram for air compressor.How can i calculate pressure drop in pipe.
As long as the velocity of the air flow < 0.3 Mach, the incompressible flow equations (Darcy-Weisbach) can be used to calculate pressure drop in a piping system. Once speed > 0.3 Mach, then a different analysis using compressible flow is called for.
I don't know what you mean by 'Can I use moody diagram for air compressor?'
Crane Technical Paper 410 covers some simple compressible flows for air and other gases. It's worth laying your hands on a copy.
I found a formula from atlas copco manual
p1-p2=(450*(q^1,85)*L)/((d^5)*p)
q=air flow (l/s)
d=internal pipe diameter(mm)
l=length of the pipe bar(a)
p=absolute initial pressure
atlas copco products air compressor.Can i use this formula to calculate pressure drop in pipeline?
It's worth a shot. Remember, pressure is in units of bars.
air compressor Q=2,6m^3/min D(diameter)=50mm P(pressure)=7,5Bar
V=Q/A ---> V=4*(2,6/60)/(3,14*0,05^2)
V=22,08m/s MACH=22,08/340=0,064
Can i use incompressible flow equations(DARCY-WEİSBACH)?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
