Characteristic Impedance for a (∏) two port network
The discussion revolves around calculating the characteristic impedance (Z0) of a two-port network, with specific emphasis on the Z parameters. Initial calculations yield Z11 as 24 Ω and Z21 as 13.32 Ω, while Z22 is also determined to be 24 Ω. The term 'characteristic impedance' is clarified as typically associated with transmission lines rather than Z parameter networks. The final calculation for Z0, derived from the provided formula, results in approximately 17.88 Ω, though some participants express concerns about the clarity of the arithmetic steps leading to this conclusion. The discussion concludes with a request for confirmation of the final answer's accuracy.
agata78
Calculate the Characteristic Impedance (Z0) of the two port network?
When port 2 open-circuit, I2 = 0
So, Z11 = V1 / I1
= 40(60) / 100 = 24 Ω
When I2 = 0, thus V2
V2 = 40 / 20+40 V1 = 0.666 V1
Z21 = V2 / I1
= 0.666 V1 / (V1 / 40-20)
= 0.666 V1 / (V1/20) = 0.666 V1 : V1/20
= 0.666 V1 x 20/v1
= 0.666 V1 x 20 / V1
= 13.32 V1 / V1
= 13.32 Ω
Now, when I1 = 0, so:
Z22 = V2 / I2
= 40(60) / 100
= 2400 / 100
= 24 Ω
When port 2 open circuit, I1 - 0, so:
V1 = 40 / (20+40) V2
= 40 / 60 V2
= 0.666 V2
I2 = V2 / 24
Z12 = V1 / I2
= 0.666 V2 / (V2 / 24)
= 0.666 V2 : (V2 / 24)
= 0.666 V2 (24/ V2)
= 15.984 Ω
AM I CORRECT?
Can someone please help?
Write the equations defining Z parameters, then set i2 = 0.
I have never heard the term 'characteristic impedance' apply to z parameter networks. It's used in transmission lines.
When your network is symmetrical, Z12 has to equal Z21.
Why are you going to all the trouble of calculating the Z parameters, and the voltage transfer ratios, when (apparently) all you want is the characteristic impedance?
And, if you want the characteristic impedance, why did you stop your calculations before you calculated it?
Z0 = √ R1 x R2² / R1 + (2 x R2)
Z0 = √ 20 x (40)² / 20 + (2 x 40)
Z0 = √ 20 x 1600 / 20 + 80
Z0 = √ 32000 / 100
Z0 = √ 320
Z0 = 17.8885
Z0 = 17.88 Ω
Can someone please confirm that I am correct? Much appreciated!
Your final answer is correct, but your arithmetic procedures leading to it are not unambiguous.
