Showing that the complex functions are constant in t.
MelissaJL
Showing that the complex functions are constant in t. Please Help! :)
The complex position vectors of two parallel interacting equal fluid vortices moving with their axes of rotation always perpendicular to the z-plane are z1 and z2. The location of the vortices are then given by their respective coordinates x1,y 1 and x2, y2. It turns out to be useful to think of these coordinates as specifying a point in the complex plane, in which case the locations of the two fluids at a given time t are given by two complex numbers z1(t)=x1(t)+iy1(t) and z2(t)=x2(t)+iy2(t). The equations governing their motions are:
\frac{dz*_{1}}{dt}=\frac{-i}{z_{1}-z_{2}}
\frac{dz*_{2}}{dt}=\frac{-i}{z_{2}-z_{1}}
(1) Deduce that (a) z1+z2, (b)z1-z2, (c)z12+z22 are all constant in time,(2) and hence descibe the motion geometrically.
General z:
z=x+iy
Complex Conjugate:
z*=\overline{z}=x-iy
Modules of Norm of z:
|z|=\sqrt{(z*)z}=\sqrt{x^{2}+y^{2}}
A constant function is define by:
\frac{df(t)}{dt}=0 OR f'(t)=0
Wow. That was a "wordy" question. So I think I got 1.a but I'm requesting help on the rest of the question.
(a) z1+z2
Now I'm not sure if I should be showing whether
\frac{d}{dt}[z1+z2]=0
Or if
\frac{d}{dt}[z1]+\frac{d}{dt}[z2]=0
Either way for this question I get...
\frac{d}{dt}[z1]+\frac{d}{dt}[z2]=[\frac{d}{dt}[z*1]+\frac{d}{dt}[z*2]]*=[\frac{-i}{z_{1}-z_{2}}+\frac{-i}{z_{2}-z_{1}}]*=[\frac{-i}{z_{1}-z_{2}}+\frac{-i}{-(z_{1}-z_{2})}]*=[\frac{-i}{z_{1}-z_{2}}+\frac{i}{z_{1}-z_{2}}]*=[\frac{-i+i}{z_{1}-z_{2}}]*=[0]*=0
(b) z1-z2
This is where I start to get lost. I apply a similar method:
\frac{d}{dt}[z1]-\frac{d}{dt}[z2]=[\frac{d}{dt}[z*1]-\frac{d}{dt}[z*2]]*=[\frac{-i}{z_{1}-z_{2}}-\frac{-i}{z_2-z_1}]*=[\frac{-i}{z_{1}-z_{2}}+\frac{i}{z_2-z_1}]*=[\frac{-i}{z_{1}-z_{2}}+\frac{i}{-(z_1-z_2)}]*=[\frac{-2i}{z_{1}-z_{2}}]*
And I don't know what to do to make it zero.
(c) I have not attempted yet.
(2) I don't know how I would represent them geometrically on an x,y plane.
Thank you for the help, I really appreciate it and the work you guys do on here :)
First: yes ##\frac {d(z_1 +z_2)}{dt} = \frac {z_1}{dt} + \frac {z_2}{dt}.## d/dt is always a linear operator.
For part b you are practically there. You didn't apply your conjugate in the last step. (It had to be a minus sign somewhere).
For the ##z^2## situation, you need to use the chain rule. df/dt = df/dz##\cdot## dz/dt.
Re geometric representation, unfortunately I am geometry-blind -- I have no idea how things look; but I'm sure someone else will help.
brmath clearly meant \frac{dz_1}{dt}+ \frac{dz_2}{dt}.
For the "geometric representation", if z_1- z_2 and z_1+ z_2 is constant, then so is (z_1- z_2)(z_1+ z_2)= z_1^2- z_2^2. If, in addition, z_1^2+ z_2^2 is constant, so is (z_1^2+ z_2^2)+ (z_1^2- z_2^2)= z_1^2 which, of course, means that z_2^2 is also always constant. This set will consist of four points: (a, b), (-a, b), (a, -b), and (-a, -b).
yes, that is indeed what brmath mean
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
