Calculating Photon Momentum and Speed for a 1205 kg Spaceship with a Square Sail
  • Thread starter Thread starter thatguy101
    Photons
The discussion focuses on calculating the speed of a 1205 kg spaceship with a 26.3 m square sail after 21 days, given the incident photon flux and momentum. The initial calculations yield a force of 0.00345 N on the sail, leading to a velocity of approximately 5.19914 m/s. However, the accuracy of the result may be affected by significant figures or the assumption regarding photon reflection. It is suggested to use symbolic representation for clarity before substituting numerical values. The final answer may need reevaluation based on these considerations.
thatguy101
In space near earth, about 3.84*10^21 photons are incident per square meter. On average, the momentum of a photon is 1.3*10^-27. Assume we have a 1205 kg spaceship, and a square sail that is 26.3m wide.
How fast could the ship be traveling after 21 days?
F*Δt=m*v
I started out by finding the force the photons would have on 1 m^2 and then multplied that by 26.3 to get the force on the sail
(1.30*10^-27)(*3.84*10^+21)*(26.3^2)
and got .00345 N
Since F=ma, I divided that by 1205 to get 2.865*10^-6
I then took 21 days and changed it to 1814400 s. So i multiplied 2.865*10^-6 by1814400 to get 5.19914 m/s. Did i go wrong somewhere cause the computer says I am wrong.
Hello.
Is any information given about whether or not the photons are reflected back by the sail?
F*Δt=m*v
Your method is right. It may be a matter of significant figures. Try to work out the solution using symbols and plug in numbers at the end. It makes it easier to follow:
Fsail = dpship/dt= ndpph/dt = σAdpph/dt where σ is the number of photons per unit area
mΔv = FΔt = ΔtσAdpph/dt
AM
