Daniel Luo
- 23
When an oil drop falls freely, the velocity first increases, but afterwards it quickly reaches a constant speed, since the air resistance becomes equal to the weight of the oil drop. The air resistance is given by:
Fair=6\pir\etav,
where \eta is the viscosity of air with a value of 1.759*10-5 N s/m2, Oil's density is 918.7 kg/m3. In Millikan's experiment, the speed of the oil drop is 5.449*10-4 m/s.
- Find the radius and mass of the oil drop.
Afterwards, electricity was sent through the plates, and the speed of the oil drop increases by 5.746*10-4 m/s. The upward electric force acting on the oil drop is given by:
FE=qE,
where E is the electric field strength: E = 3.178*105 N/C.
Find the electric charge of the oil drop, q.
For no. 1:
Weight = Air resistance
mg = Fair=6\pir\etav,
\rhoVg=Fair=6\pir\etav,
No. 2:
FE=qE
mg = FE + Fair
All right. What I did in no. 1 was to say that the weight was equal to the air resistance. Assuming the drop to be spherical, I said:
\rho(4/3\pir3)g = 6\pir\etav. Then I solved for r:
r = 2.19*10-6 m
And I found m:
m = \rho(4/3\pir3) = 4.04*10-14 kg (This seems to be too light even for a raindrop?)
For no. 2: I said that the weight was equal to the sum of air resistance and the electric force:
mg = 6\pir\etav + qE
Solving for q gave: q = -1.31*10-18 C.
However, this answer seems wrong, as Millikan tried to find the charge of the electron e from this experiment, which is 1.602*10-19 C.
Have I done something wrong? In case I did, what was my mistake?
Thanks a lot!
