Determine which mass is going to reach the bottom first
  • Thread starter Thread starter fireblasting
    Mass
The discussion centers on a physics problem regarding which mass reaches the bottom of an incline first, specifically question number 20 from a multiple-choice test. Participants clarify that the time taken does not depend on mass due to the conservation of energy, leading to the conclusion that all masses will have the same velocity at the bottom. Key equations discussed include gravitational potential energy (Ug=mgh) and kinetic energy (KE=(1/2)mv^2). The conversation also emphasizes the importance of analyzing the shape of the incline and its effect on acceleration and time.
  • Understanding of gravitational potential energy (Ug=mgh)
  • Familiarity with kinetic energy equations (KE=(1/2)mv^2)
  • Knowledge of conservation of energy principles
  • Ability to interpret free body diagrams and net forces
  • Study the implications of conservation of energy in different physical scenarios
  • Learn about the dynamics of motion on inclined planes
  • Explore the concept of elliptic integrals and their applications in physics
  • Investigate the effects of different incline shapes on acceleration and time
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the dynamics of motion on inclines and the principles of energy conservation.
fireblasting
The problem includes some pictures, so I will post the link here: http://faculty.polytechnic.org/cfle...pdfs _Jan_2010/zq-Mult Choice Test 3 csb.pdf
It is question number 20
Ug=mgh
KE=(1/2)mv^2
Since the inclines are frictionless, the time depends on the mass, velocity, and distance travel. However, the mass is not given, so I don't know how to approach the problem. Can somebody please help me out with this?
time would depend on the initial net acceleration. It would help if you draw free body diagram and check the net force acting on body. Would the net force depend on slope of incline?.---------->The correct answer to this question would answer your question.
Caution: They all will have same velocity at the bottom!
The equations marked as relevant are indeed very relevant here. Total energy is conserved, hence ## v = \sqrt {2gh} ##. Now, ## v = ds/dt##, hence $$ dt = \frac {ds} {\sqrt {2gh} } $$ As soon as you figure out the dependency ## ds = f(h) dh ##, you will be able to set up and compute the integral $$ T = \int\limits_R^0 \frac {f(h) dh} {\sqrt {2gh}} $$
The time does not depend on the mass. Forces will be proportional to mass, but as F=ma, the mass cancels out again when you calculate an acceleration.
[Edit: Merged replies and deleted the second thread, I did not see this thread]
@voko: I doubt that he is supposed to perform that integral for the curved shape in a multiple choice test.
Hmm. I may be overthinking the problem, but I don't see an easier way to compare #3 with the other two.
The length of the tracks in 2 and 3 is the same, this makes a comparison easy. And 2 and 1 can be compared with each other as well.
I am still not seeing that.
The final equation has an error, it should be $$ T = \int\limits_0^R \frac {f(h) dh} {\sqrt {2gh}} $$ Now, taking ## x = \sqrt {R^2 - h^2} ##, we get ## ds = R (R^2 - h^2)^{-1/2} dh ##. Further taking ## h = R u ##, we end up with $$ T = \sqrt {\frac {R} {2g}} \int\limits_0^1 (u(1 - u^2))^{-\frac 1 2} du $$ That is an elliptic integral, so it is very dubious indeed that this is supposed to be the way to solve the problem.
I don't think that they ask to calculate the time.
Just look at the pictures. The one "closest to a free fall" will be first.
I took a different approach and ended up with $$T=\sqrt {\frac {R} {2g}} \int_0^{\pi/2} \frac{d\theta}{\sqrt{\sin\theta}}$$ This also is an elliptic integral. Your result is the same as mine, just expressed differently.
This is less time than is needed to slide down a straight ramp with the same path length. I too find it dubious that either your approach or mine is the one expected to be used to solve the problem.
If we just want to answer the question as to which one hits the ground the fastest, I suggest you create a problem where you have a two cases. See my diagram. Figure 2 shows a ramp 20 units long with a height of 15. Figure 1 shows a broken ramp with total length 20 and a height of 15. Now it is easy to calculate which one will hit the ground first.
What does that mean, though?
Let's add two more objects to slide down. Masses m4 and m5 traverse the same horizontal distance as that traversed by mass m3. Mass m4 slides down a 45 degree ramp, and for mass m5, the curve followed is a segment of an inverted cycloid. Mass m5 will take the least amount of time and mass m4 the most. How does "closest to free fall" distinguish between these three curves?
You can do a bit better than just looking at the pictures. Compare the speeds after traveling some given distance s. in the curved path, it will have descended further for any s less than the whole distance.
I did not say you can "guess" for any arbitrary trajectories.
I am sure you can find any number of paths where you need to calculate to find the actual time.
But here they picked nice examples so you can try a guess without calculations.
The circular path starts with the highest acceleration (g at the top). And even though at some point the acceleration becomes lower than on any of the two inclines, the average speed will be higher and the distance shorter. Of course, this is not a mathematical proof, just some semi-intuitive estimate. But do you really think they expected to solve numerically these integrals?
Heavens no! These questions might well be for a non-calculus based physics class.
haruspex' method works quite nicely and is at an appropriate right level.
I did not mean look without thinking. :smile:
Bit I did not explain as well as you did, you are right.
  • · Replies 19 ·
