Fourier Series Help: Isolated Pulses, Width "w", +-D
  • Thread starter Thread starter AntonVrba
    Series
The discussion focuses on deriving the Fourier series for two isolated pulses with a pulse width "w" spaced "2D" apart. The coefficients B_n are zero due to the symmetry of the function, and the period is established as 2D. The calculations yield A_n and A_0, leading to the expression for y(x) that confirms the maximum width of W can be 2D. A plot is included to visualize the series for specific values of W, D, and h, demonstrating the equivalence of the derived expressions. The author corrects an earlier mistake, affirming the accuracy of the final results.
AntonVrba
I am 52, not yet senile and would be greatfulif someone can give me the Fourier series of two isolated pulses, pulswidth "w" spaced "2D" apart or at +- D.
Thanks in advance
I will try it, but don't have a program to check my calculations.
This function is symetrical. So the coeficients B_n are 0. The period is 2D.
A_n = \frac{2}{D}\int_{0}^{D} cos\left( \frac{n\pi x}{D}\right)y(x)dx = \frac{2h}{D}\int_{D-W/2}^{D} cos\left( \frac{n\pi x}{D}\right)dx = \frac{2h}{D}\left[\frac{D}{n\pi}sin\left( \frac{n\pi x}{D}\right)\right]_{D-W/2}^{D}
A_n = \frac{2h}{n\pi}sin\left( \frac{n\pi W}{2D} - n\pi \right) & n=1,2,...
A_0 = \frac{Wh}{D}
\Rightarrow y(x) = \frac{Wh}{2D} + \frac{2h}{\pi}\sum_{n=1}^{\infty}\frac{1}{n}sin\left( \frac{n\pi W}{2D} - n\pi \right) cos\left( \frac{n\pi x}{D}\right)
This makes sense, because the bigest W can be is 2D wide. In this case, the function is y(x) = h, which is correct. (h is the height of the pulse)
I get:
y(x)=\frac{Wh}{2D}+\frac{2h}{\pi}\sum_{n=1}^{\infty}\frac{1}{n}Sin[\frac{n\pi W}{2D}]Cos[\frac{n\pi}{D}(x-c-\frac{W}{2})]
with:
c=\frac{2D-W}{2}
I've included a plot for:
W=5
D=10
h=1
for the first 25 terms of the series
Our expressions are equivalent, in case you haven't noticed.
-c-\frac{W}{2} = \frac{-2D+W-W}{2} = D
and
\cos\left(\frac{n\pi}{D}(x+D)\right) = \cos\left(\frac{n\pi x}{D}+n\pi\right)=-\cos\left(\frac{n\pi x}{D} \right)
So it's cool.
Edit: Wait, that's not true
Ok I corrected an error in my original post due to this false identity that I had used.
Now our expressions are equivalent.
