Conservation of angular momentum in an inelastic collision?
In the discussion on the conservation of angular momentum during an inelastic collision, a clay blob collides with a bar on a frictionless table, raising questions about final speed and angular velocity. The calculations for the center of mass and moment of inertia are crucial, with the need to apply the Parallel Axis Theorem for accurate results. Participants clarify the contributions of the clay and bar to the system's moment of inertia, emphasizing the importance of calculating the inertia about the new center of mass. The initial confusion about the moment of inertia is resolved, leading to the correct angular speed calculation. The discussion highlights the complexities of angular momentum conservation in inelastic collisions.
mot
On a frictionless table, a glob of clay of mass 0.380 kg strikes a bar of mass 0.9 kg perpendicularly at a point 0.550 m from the center of the bar and sticks to it.
a) a) If the bar is 1.300 m long and the clay is moving at 8.100 m/s before striking the bar, what is the final speed of the center of mass? (Got this, 2.405m/s)
b)At what angular speed does the bar/clay system rotate about its center of mass after the impact (in rad/s)?
Li=Lf
L=r x p =mrv (when theta = 90, as in this case)
L=Iw
I of a rod = (ML2)/12
xcenter of mass=Ʃmx/Ʃm
m = mass of clay
M=mass of bar
u=clay's initial speed
r=the distance from the clay to the new CM
So I set one end of the bar as x=0 and the other as x=1.3 to calculate CM
CM=((0.38)(0.65+0.55)+(0.65)(0.9))/(0.9+0.38)=0.81328m from the end of the bar
r=1.2-0.81328=0.3867m
Initial angular velocity=mru
Final " "=((1/12)ML2+mr2
so ω=(mru)/((1/12)(ML2+mr2)
When I plug in my values, I get the wrong answer, it is supposed to be 5.73. Where am I going wrong? I have spent hours at this :( I'm so frustrated!
mot said:
On a frictionless table, a glob of clay of mass 0.380 kg strikes a bar of mass 0.9 kg perpendicularly at a point 0.430 m from the center of the bar and sticks to it.
Li=Lf
L=Iw
m = mass of clay
M=mass of bar
Where are the data in red come from?
You need the moment of inertia with respect to the new CM. (1/12)ML2 is the moment of inertia with respect to the centre of the rod.
ehild
Sorry I made a typo in the question, 0.43 should have been 0.55. I've fixed it now. (1.2 is 0.65+0.55, the "position" of the clay on the rod with respect to the end).
That's what I was thinking with the moment of inertia...but doesn't adding the mr^2 take that into account?
I could also do I=Ʃmr^2, where r is the distance from the new CM
=(0.9)(0.81328-0.65)^2+(0.38)(0.3867)^2=0.0808
and my old I=((1/12)(0.9)(1.3^2)+(0.38)(0.3867^2))=0.1836
The new I gives me 14.7rad/s when I plug it into the equation:(
No. That's the blob of clay's contribution to the moment of inertia of the bar+clay system. The bar's contribution is the moment of inertia of the bar about the combined center of mass.
Hint: Parallel axis theorem.
Thanks so much guys, I got it! It seemed so obvious this morning, I guess that's why you shouldn't do physics at 2am. I was comparing it to a question I had done with a mass on a rotating disc, forgetting that the disc was still rotating about the central axis
