Solve] Time to Boil 1.1 kg Water with 1500 W
  • Thread starter Thread starter k31453
    Thermodynamics
To determine the time required to boil away 1.1 kg of water using a 1500 W stove burner, the latent heat of water must be considered. The relevant equation for heat transfer is q = mct, where 'm' is mass, 'c' is specific heat, and 't' is time. After reaching the boiling point, the energy needed to convert the water to steam can be calculated using the latent heat of vaporization. The relationship between power, energy, and time will then provide the final time needed for the process. This approach ensures an accurate calculation of the boiling time.
k31453
A stove burner supplies heat to a pan at the rate of 1500 W. How
long will it take to boil away 1.1 kg of water, once the water
reaches its boiling point?
q = mct
heat transfer = 1500 W, m = 1.1 KG Tf = 100
Look up latent "heat of water". That will allow you to calculate the amount of energy needed to turn 1.1kg of water at 100C into steam at 100C.
Then remember the equation that relates Power, Energy and Time.
